Switch out of sync and churn state is already true. Churn Timer should not have been existing.
Check to see if the port being used is valid. Check the port state and the corresponding timer associated with it. show lacp show process lacp show lacp member-port <port> {detail}
Warning
Invalid Churn detection timer state. State TRUE Port %port% type %type%
| Name | Type |
| port | String |
| type | String |
